Thursday, April 2nd, 2009 AT 7:54 PM
Over the past year, my temperature gauge and overheat warning light have been indicating overheat problems with my car (it's not my daily driver). So far, we have replaced the thermostat, the water pump, the radiator, the sensor that the gauge plugs into in the block, and an electrical relay switch. We are still having the same problem. After running a while, when I check the block temperature (with an "aim-at" remote sensor), the external temp is about 190 degrees. The car has also been checked for head gasket issues, and we're told there's no problem there. HELP--any thoughts you have would be greatly appreciated!
