Is the car stalling?
A bad or dirty throttle body will give the code for the throttle valve positioner. This may be causing the car to stall and the crank position sensor code might just be a symptom of the first problem.
I would address the throttle valve issue first, then look into the crank position sensor only if the code returns.
SPONSORED LINKS
Wednesday, September 9th, 2009 AT 12:26 PM
