2001 Volkswagen Cabrio Transmission Shifting Problems - May
80,000 MILES • 4 CYL • 2WD • AUTOMATIC
MCGUCKIN
  • 6 POSTS
Not sure if this is a problem (daughters car I don't usually drive). 4 speed automatic that I can't seem to tell or see that its shifting gears. When you give it gas the RPM and speed just increase with no apparent movement in the tach that shows a shift. I'm wondering if anyone knows what the RPM should be at each speed-gear. When the CAR is doing 45 the RPM is at about 3000. Worried the car may be in a lower gear - not sure
Nov 25, 2009 at 5:43 AM
  • 31,937 POSTS
Hi there thank you for the donation,
These cars have a silky smooth transmission shift, with out driving the car it is a bit hard to tell what it is doing, i would suggest that you visit a transmission specialist and get them to do a road test with you if you have any doubts about the performance of the transmission, best to be safe , i have not been able to find any shift pattern specs on this, so a road test will be the best way to determine if there is a fault.
mark (mhpautos)
Nov 27, 2009 at 11:25 AM
MCGUCKIN
  • 6 POSTS
Mark - Thanks - I could relay use your help on the technical info. What should the specs call for the RPM to be in OD doing 50 MPH - 2800-3000RPM ? I'm trying to figure out what the gear RPM's should be. I can't seem to find it on the net that;s my main question. Thank you
Nov 27, 2009 at 11:38 AM
  • 31,937 POSTS
Hi there,
yes , this info i rather hard to find, i will be checking some tech sites and will post what i come up with, but as to date i have hit the wall as well, but i will keep looking.
mark (mhpautos)
Nov 27, 2009 at 2:03 PM
  • 31,937 POSTS
Hi there, I just can't find anything on this all i keep coming up with is this....
https://images.2carpros.com/forum/automotive_pictures/61395_Noname_90.jpg
I can get all the info on ratios , gear sets teeth counts etc, but nothing else, i will keep looking but i don't know if will do any good, here's hoping. Mark
Nov 27, 2009 at 3:06 PM
MCGUCKIN
  • 6 POSTS
Mark - Thanks I appreciate you trying. My concern and why I want to find out the guide for RPM's should be is that my wifes car (2000 Town & Country Van) with 3.3L RPM's at 1500 at 60MPH. I know its a larger engine than the VM (2.0L) but I'd like to see what the specs are as at 50 the RPM is about 3000. Thanks again
Nov 28, 2009 at 2:36 AM
  • 31,937 POSTS
I will have a talk to my local transmission re builder on Monday, they may have something for you,
Mark
Nov 28, 2009 at 8:48 AM
MCGUCKIN
  • 6 POSTS
Hi Mark - Wondering if you had any luck
Nov 30, 2009 at 1:27 AM
  • 31,937 POSTS
HI there,
I had a chat with my transmission tech, they don't have rev to road speed averages, they work on live data from the ECU downloaded to a laptop while they drive, this is calculated as pressure and sensor readings under road speed and load conditions, i could almost hear the gears clicking in his head as he said that we haven't done tests like that in years, the technology has moved on well past that now, i am of the old school and i would have thought that this would be a fairly simple thing to get, but this has been not the case, i can only suggest that you get a local trans tech to take it for a drive and get their advice first hand, as i am in Australia, i can't advise on who is best suited to help you, i would suggest that you look for a national branded transmission group, i feel that they will give you the bast attention.
Mark (mhpautos)
Nov 30, 2009 at 7:17 AM
