2003 Volkswagen Beetle
131,000 MILES • 4 CYL • FWD • MANUAL
FARCHIEF
EPC light comes on intermittently... check engine light stays on continuously. Engine loses power for short periods, sputters and coughs on occasion, and sometimes quits altogether, but will normally start right back up again. Is it possible that a plugged air filter could be causing this?
Apr 7, 2010 at 2:05 AM
2CARPRO JACK
  • 11,533 POSTS
Not likely or it wouldnt come and go.You will need to have the PCM scanned for trouble codes.The light is the cars computer (PCM) way of telling you it sees a problem with one or more monitored systems.The code/codes should lead to the fix
Apr 9, 2010 at 12:41 AM
