2002 Volkswagen Beetle
2002 VOLKSWAGEN BEETLE
EARGADIN
2002 Volkswagen Beetle 6 cyl
Hello. My bug is making a rattling noise when the tachometer is on the "2" dash mark. What is wrong with my car?
Apr 13, 2010 at 1:34 PM
2CARPRO JACK
  • 11,533 POSTS
Gonna need a little more info than that. Does it continue to make the noise past 2 on the tach? does acceleration change it? does it do it at 2 in all gears or at a particular speed? Does the noise sound tinny, like a bolt in a coffee can? any work been done to the car?
Apr 15, 2010 at 2:02 PM
EARGADIN
[quote:b8e99def87="2CarPros Jack"]Gonna need a little more info than that. Does it continue to make the noise past 2 on the tach? does acceleration change it? does it do it at 2 in all gears or at a particular speed? Does the noise sound tinny, like a bolt in a coffee can? any work been done to the car?[/quote:b8e99def87]
Oh! I'm sorry. It doesn't make the rattling noise past the 2 and accelerating makes the noise stop. The noise sounds like something is dragging on the ground, but nothing is. It does it around the 20 or 30 MPH mark. Work hasn't been done on my car for a while.
Apr 15, 2010 at 2:33 PM
2CARPRO JACK
  • 11,533 POSTS
There are still alot of things it could be.The dragging sound is where we are going with this.It may be a bad wheel bearing.You need to lift and support the vehicle and check for a "loose" wheel.The wheel will have play in it even if tight if the wheel bearing is going out.Also spin thewheel to see if it feels rough or makes any noise.Have the brakes been checked recently?
Apr 15, 2010 at 11:29 PM
EARGADIN
They have yes.
Apr 16, 2010 at 5:42 AM
2CARPRO JACK
  • 11,533 POSTS
then check the wheel bearings
Apr 16, 2010 at 7:36 AM
