1999 Volkswagen Beetle Engine jerking
1999 VOLKSWAGEN BEETLE
120,300 MILES • 4 CYL • 2WD • MANUAL
APINEIRO
I have a '99 VW beetle that I just bought from a co-worker who told me "make sure you warm it before you take off because it'll go crazy". Every morning since I have been warming up the car for at least 20 minutes before going anywhere and when I take off it jerks a little going into second gear mostly, but then goes away. However, just recently I warmed it up as usual, tried to take off and it began jerking pretty violently. It felt like an automotive seizure! I tried going into second and third gear but the jerking continued. I also tried giving it gas and it basically didn't pick up the gear. It also did the same thing when i didn't warm up the car. Sometimes, I can smell a gasoline-like odor and it'll make a low "put-put"sound that I can hear under the car. Help??
Oct 15, 2010 at 8:09 AM
  • CAR REPAIR CONTRIBUTOR
Lack of acceleration,chugging,hesitating,jerking,bogging,misfiring etc. could be caused by one of the following below
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it
Oct 16, 2010 at 12:06 AM
