1972 Volkswagen Beetle I think the brakes are rusted and lo
MSEANODONNELL
Brakes problem
1972 Volkswagen Beetle 4 cyl Two Wheel Drive Manual
I have it in neutral and the parking brake is loose, but I cannot get the car to roll. The car isn't running right now either, but I need to get it to push so I can get it in the garage. What should I do?
Jan 28, 2010 at 10:21 AM
  • 31,937 POSTS
Hi there, jack up the car and back off the brake adjusters fully, then you will need to remove the split pin on the rear hub and get a socket and bar on the axle nut, working the axle back and forth should start to free up the brakes if the adjusters don't
Mark (mhpautos)
Jan 28, 2010 at 11:54 AM
