Rough Idle and stalls
1969 VOLKSWAGEN BEETLE
MIROGANITA
My wife and I recently bought a vintage VW Beetle, after a little work it ran just fine for about three months. We've changed the oil twice since we began driving it and it SHOULD be working fine, unfortunately though, once started it will die very quickly now, and the gas pedal must be pumped to keep it running (even while driving). It has electrical issues galore, and I am fairly sure we need to flush the gas lines. It also backfires on a regular basis, but when we check the plugs, they look fine.
If anyone could give me a little advice on where to start, that would be great. Thanks in advance!
Jun 3, 2010 at 7:23 AM
CZYZMAN
With everthing you said, especially the backfiring, I suspect a loose head. Have a buddy do whatever it takes to get it to run. Take one spark plug wire off, then put it back on. If you do this to all of the cylinders, it can tell you if there is a leak. If the engine comes close to dying when the plug is yanked, the cylinder is good. If it makes almost no difference and the engine is still running, there is a leak. If both cylinders on the same side of the engine are "Bad" I would have to tell you that you have a loose head. If it is just one cylinder, or the two are on opposite sides of the motor, adjust your valves. Mine are currently set at .016 clearance to make up for the expanding metal as the engine heats up. If the adjustment does nothing to the cylinder(s), You have a burned or mis-seated valve. If all of the spark plugs make quite a difference in the opperation, then try adjusting the fuel mixture. The accelerator pump squirts extra gas into the engine when the pedal goes down to avoid stalling on acceleration. So when you pump the pedal, all your doing is raising the idle RPM and introducing more fuel. My adjustment screw is the smaller one on the side of the carburator opposite of the generator. Turning it to the front of the car (left) Increases fuel, and vice-versa. Only turn it a half of a turn each time you try to start it to avoid flooding. If you suspect it flooded, because it will not fire, just remove the spark plugs and crank it a few times, then put them back in. My 67 Bug got the loose head problem 3 times and the symptoms you list fit perfectly. Hope this helps in some way or another, but please check for a loose head before doing anything else to avoid causing more issues for yourself. Good Luck
Jun 5, 2010 at 6:01 AM
