Violent jerk
2005 HYUNDAI SANTA FE
115,100 MILES • 3.5L • V6 • 4WD • AUTOMATIC
MARILW
My vehicle jerks violently one time at about thirty mph then goes back to normal. Sometimes it does it sometimes it does not. But most of the time it does it. Only when I am holding the pedal down or coasting and reach thirty mph. If I tap the peddle until I get past thirty mph it does not jerk. The code for the throttle position sensor popped up when checked. Transmission fluid is also dark. Could the sensor be the problem or could the transmission be going bad? A mechanic stated that the team may be going bad but I do not think so. I need another opinion because I think he is just trying to get more money for putting in a new transmission.
Mar 7, 2017 at 8:38 PM
HMAC300
  • 48,601 POSTS
if the engine is not running right neither will transmission. fix the problem first then see what happens. the jerk will probably go away. clean the throttle plate and IAC hole with choke cleaner as well.
Mar 7, 2017 at 11:02 PM
