Vibration from front?
2006 BMW Z4
95,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,007 POSTS
I bought this car with a top issue, but got that fixed, Tires look new at first glimpse, no check engine light, no engine issue. Took it for a drive and shifts fine but there is a vibration up front, not in the steering, starts around 25 and up. Would wheels be the first suspect? Could a bad tire also cause that? No shimming when braking, suspension is tight, I checked control arms by hitting the brakes hard and steering didn't go to one side.
Jan 29, 2024 at 8:54 AM
  • 110,240 POSTS
I would think if it was a tire, wheel, or something related to either of those, you would feel it in the steering as well. Often, if the vibration is felt in the floor or seat, it is one of the rear tires. What makes you say it's from the front? Do you feel it in the brakes?
Do me a favor. After driving the vehicle a few miles, get out and see if there is excessive heat from either wheel. You may have a brake hanging up and overheating.
Also, yes, it could be a wheel, tire, bearing, and so on. Let me know if you hear any odd sounds or notice any odors.
Jan 29, 2024 at 11:34 AM
BHAMDOC1973
  • 2,007 POSTS
Checked tire pressure and one on front had 12.9 the other 22, rear were 24 each. So, all were out. Inflated all and will see hopefully that was it.
Jan 30, 2024 at 10:13 PM
  • 110,240 POSTS
Wow, that is a problem. LOL Make sure the tires are worn evenly and have not shifted belts.
Let me know if this resolves the issue.
joe
Jan 31, 2024 at 4:52 AM
BHAMDOC1973
  • 2,007 POSTS
Balanced the wheels myself and placed the front wheels on rear...way better now, only does vibrate some when I hit it heard at 60mph, am thinking it's in the drive train, maybe the flex disc.
Feb 4, 2024 at 12:29 AM
  • 110,240 POSTS
Anything is possible. However, since you eliminated a lot of the vibration with what you've done, I suspect it may still be one of the wheels or tires. When you balanced them, did you inspect the tires for a bent rim, shifted belts, or uneven tire wear?
Also, when you are feeling it now, do you notice it in the steering wheel, or does it seem to be in the floor and seat of the vehicle?
Feb 4, 2024 at 10:28 AM
BHAMDOC1973
  • 2,007 POSTS
Tires are different brands, but all around 50-60% and no obvious wear that can cause this thing. Didn't see any indication of a bent rim. I feel it in steering and in floor.
Feb 4, 2024 at 8:19 PM
  • 110,240 POSTS
If you are feeling it in the steering, the tires are balanced, there are no indications of tire or rim damage, then we need to suspect something with an axle joint. Are any of the CV boots leaking?
Take a look at this link and let me know your thoughts:
https://www.2carpros.com/articles/symptoms-of-a-bad-cv-axle-joint
Feb 5, 2024 at 9:56 AM
BHAMDOC1973
  • 2,007 POSTS
No CV up front it's a rear wheel drive.
Feb 5, 2024 at 10:16 AM
  • 110,240 POSTS
Sorry about that. I'm thinking AWD. Have you checked to make sure there aren't any issues with the driveshaft? There is a rubber flex coupler that could be faulty and causing this. See pic below.
Check to see if there is evidence of cracking or play. There is a coupler at both the front and rear of the drive shaft.
See pic below.
Feb 6, 2024 at 12:27 PM
BHAMDOC1973
  • 2,007 POSTS
Yes, that's what i thought. But I haven't checked it yet. Once i rotated the wheels and reassured me the tire pressure was exactly where it is now it drives hardly any good, but I'll still check it out. Thank you
Feb 6, 2024 at 8:48 PM
  • 110,240 POSTS
Sounds like a plan. When you check them, look for any cracks or damage to the coupler. They can cause a vibration when they fail.
Take care of yourself.
Feb 7, 2024 at 7:52 AM
