Vibration at 40 km/h while accelerating
2013 FORD TERRITORY
170,000 MILES • V6 • 4WD • AUTOMATIC
NICKERS987
While recently towing a trailer it is worse but is now happening without the trailer attached. When accelerating at low speeds between 40-60km/h there is a shuddering coming through the accelerator pedal and can slightly be felt through the whole car.
If you back of the accelerator off the shuddering eases off, if you put the pedal to the floor it's worse.
Dec 29, 2019 at 3:00 PM
SCGRANTURISMO
  • 4,897 POSTS
This could be a couple of things. It could be bad wheel bearings but I would recommend first checking your vehicle's U joints. Here are links to guides explaining how to check each of these below:
https://www.2carpros.com/articles/how-u-joints-work
https://www.2carpros.com/articles/how-to-replace-front-wheel-bearings-and-seals
Please go through these guides and get back to us with how everything turns out. Sorry we couldn't be more specific, but it looks like you are coming to us from Australia, and our reference guides only list U.S. vehicle's.
Thanks,
Alex
2CarPros
Dec 29, 2019 at 9:51 PM
