Vibration when driving
270,000 MILES • 3.4L • 6 CYL • 4WD • AUTOMATIC
MARK DULUS
Have a bad vibration between 60 and 80 mph.
May 18, 2019 at 8:57 AM
Hi Mark,
Where do you feel this vibration? If you feel it in the steering wheel or in your seat, most likely it is a tire vibration or something turning at the speed of the tires like a hub or rotor out of round. If this just started and you have not hit a large pot hole or a curb then most likely it is a tire issue.
If you feel it somewhere else, we could be dealing with a drivetrain vibration however, these are rare around the speeds you are talking about. Normally, what you are describing is a tire issue.
https://www.2carpros.com/articles/how-car-tires-work
May 18, 2019 at 10:23 AM
