Have to rev to 3000 rpm to get vehicle to move
68,000 MILES • 3.0L • TURBO • AUTOMATIC
WATIFFATED HU JIALE
Good day,
My ford vehicle required rpm 3000 to move off at d drive.
Once stop and require to move off needed RPM 3000 in order for the vehicle to move off.
I have tested with OBD2, the fault code shown 0732. Which is gear ration 2 incorrect.
Things I have done up,
1. Flush transmission system.
2. Blow clean the contact for the solenoid with contact cleaner.
3. Check the output shaft, turbine shaft and intermediate shaft sensor.
I wonder what when wrong with my transmission.
While ongoing it react normally but once the vehicle slow down, I need high rpm to move the vehicle again.
It also have a symptom of "TA" sound when moving off and it a bit scary and the rear wheel will spin while moving off.
Kindly assist me.
Jul 12, 2017 at 12:24 PM
STEVE W.
  • 15,394 POSTS
If your scan tool can read the body control module and has bi-directional testing you can use it and a hydraulic pressure gauge to test the various fluid pressures involved in the first/second shift.
Most of the time this is caused by internal part failure which you can see in the pressures. The other failure is in the BCM talking to the transmission.
If you have a reliable trans shop nearby you could have them test it, saves a lot of headaches.
Jul 12, 2017 at 1:57 PM
WATIFFATED HU JIALE
Does the solenoid B cause the problem to surface out? I am using Intergrate Dignose System (IDS) for to test the vehicle.
By the way, thank you for sharing with me.
Jul 12, 2017 at 2:16 PM
