Vehicle revving
2014 NISSAN SERENA
36,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
STEVE RAMPERSAD
When driving the vehicle starts to rev, when you switch off it starts to work normal. a pressure control solenoid B fault showing up.
Jan 21, 2019 at 12:51 PM
  • 110,244 POSTS
Pressure control solenoid B is in the transmission and is most likely responsible for the symptoms. Does it see as if the transmission is slipping? If the line pressure drops in the transmission, it will basically start to slip. That is what I believe is happening.
Let me know. Also, let me know if the diagnostic trouble code is a P0967 or P0966.
One last thought. This type of problem should fall under the power-train warranty. The factory power-train warranty is five years or 60,000 miles. I realize time may be an issue, but you should check on it. If it just ran out, I think I would argue the point.
Jan 22, 2019 at 10:21 AM
STEVE RAMPERSAD
The trouble code is p0776
Jan 22, 2019 at 2:59 PM
  • 110,244 POSTS
Welcome back:
That code is what indicated the issue with the pressure control solenoid. There are a few different things which can cause it. Here is a list:
Defective Solenoid
Dirty fluid
Clogged transmission filter
Transmission Pump
Valve Body hydraulic passages plugged
Damaged or corroded connector or wiring
Faulty PCM
Jan 23, 2019 at 9:03 AM
