2001 Vauxhall Vectra
THE PLUMBER
  • 2001 VAUXHALL VECTRA
  • 4 CYL
  • MANUAL
  • 102,000 MILES
Abs light is on
looked at the sensers can, t see anything wrong
connected ok
just had m.O.T and failed on a.B.S. Light being on only.
brakes seem to be fine ps. Stop on a 10p pease
brake test on m.O.T readings good.
but thay had to fail the car because of a.B.S. Light was on.
can you help me.
regards martin
Friday, February 20th, 2009 AT 1:22 PM
DAVE H
  • 13,384 POSTS
Check the fluid level. There is a sensor to indicate low fluid. If this is OK then it will need plugging in to a diagnostic computer to locate the fault and reset the system. Hope this helps
Saturday, February 21st, 2009 AT 7:11 AM
