1998 Vauxhall Tigra
  • 1998 VAUXHALL TIGRA
1998 Vauxhall Tigra 4 cyl
where can I locate temp sender uint for fan
. Engine overheating , fans work with external power source, am assuming sender is faulty as rad gets hot as well as engine. Temp up to 100, No fan engaged. Cant find sender can you help please. Thank you.
Saturday, May 1st, 2010 AT 11:50 AM
DAVE H
  • 13,384 POSTS
ECT (engine coolan temp) SENSOR. Is located near thermostat on cylinder head near the coolant temp SENDER which sends the signal to the dash display (2 different sensors. Look nearly the same)
Friday, May 7th, 2010 AT 4:20 AM
