is this gasket failure?
VAUXHALL
RAISEMYRENT001
vauxhall vectra 2.5 v6 sri 'arctic' 98 model 88000 miles. hi, i got oil blowing into the coolant tank.. a new oil cooler has been fitted recently, before i noticed this. the car heated up bad on my last journey. i replaced the filler cap on the expansion tank, to notice a very alarming amount of oil, in what was left of the water. seems coolant system, is full of oil, so not 'cooling'.. turned off engine, at first sign of heat up.. hav'nt run since. need to flush coolant system, but whats causing this? is this gasket failure? oil level on 'dip', into sump, is ok, and no 'butter', on underside of 'oil fill cap.. please help.. thanks.
Mar 17, 2007 at 2:45 PM
DAVE H
  • CERTIFIED EXPERT
  • 13,384 POSTS
compression test the cylinders ..suspect headgasket
Feb 16, 2009 at 12:09 PM
