1998 Other Vauxhall Models Vauxhall Omega 2.0l 16v fan belt
STUART1988
  • 1998 VAUXHALL
Engine Mechanical problem
1998 Other Vauxhall Models 4 cyl Two Wheel Drive 90000 miles
I've just done a fanbelt and tensioner on a vauxhall omega 2.0l 16v now every time I start it up the belt slips ove 1 of the pulley it doesnt fall all of the way of it just slips over 1 rib.
i was wondering if you had a diagram of how it went and if you could confirm the only reason that belt is slipping of is because one of the pulleys is not running true.
Thanks
Sunday, December 7th, 2008 AT 5:55 AM
DAVE H
  • 13,384 POSTS
I would definately say this is a pulley. Your local library should be able to supply a manual for the vehicle. The vauxhall range was not released in the USA so we do not have a diagram
Sunday, March 1st, 2009 AT 7:27 AM
