1995 Other Vauxhall Models cavalier overheating
1995 VAUXHALL
JOSSIE7
Engine Cooling problem
1995 Other Vauxhall Models 4 cyl Front Wheel Drive
my cavalier has started to overheat and i thing it could be thermostat or even radiator as when it starts to overheat the top half of the radiator is hot and the bottom is cold can you advise thanks?
Nov 30, 2008 at 5:03 PM
  • 31,937 POSTS
Hi there,
I would be replacing the thermostat and having the radiator removed pressure cleaned internally and flow tested, this should fix your problem.
Mark (mhpautos)
Nov 30, 2008 at 6:53 PM
