Perhaps the spark is too weak coming out of the coil and its not having enough to jump in the cap and properly jumping the gap on the spark plug. Have you already checked out the coil?
Next maybe the timing is off and when it does fire rotor is to far ahead of point on cap or moving away causing have the spark potential? To check this put #1 cylinder at the top of its compression stroke when it should fire the rotor should be lined up with the #1 tower for the cap.
Get back to me
and also what are you refering to as the king lead. A picture of it and the connector your holding it next to is a good help. If your refering to moving the wires I would be checking for a short possibly in the wire causing it to only have good continuity when held a certain direction
Wednesday, July 14th, 2010 AT 1:26 PM
