1995 Vauxhall Omega stalling when i switch on rear window h
1995 VAUXHALL OMEGA
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
SPIKERZ
my car is stalling when i put it into drive/reverse.it may stall at traffic lights,if i restart it try again it doesnt stall,next set of lights repeat again.also noticed revs drop with power steering,rear window heater,lights etc.(anything that takes a lot of power)and sometimes will stall.it starts and runs fine.
have replaced crank sensor,air and fuel filters,vaccum pipes,cleaned out intake manifold,egr valve.
Jul 15, 2009 at 5:50 PM
DAVE H
  • CAR REPAIR CONTRIBUTOR
  • 13,384 POSTS
check all engine vacuum pipes for leaks/damage !
Jul 17, 2009 at 5:47 AM
SPIKERZ
[quote:ebbf2cf4be="Dave H"]check all engine vacuum pipes for leaks/damage ![/quote:ebbf2cf4be]
i have done this and replaced crankshaft sensor,new air filter,fuel filter,cleaned/checked egr valve and intake manifold.
Jul 17, 2009 at 6:30 AM
DAVE H
  • 13,384 POSTS
check the alternator is putting out a constant 13.5 - 14.2 volt's !!
Jul 17, 2009 at 9:30 PM
