1999 Vauxhall Fronterra Engine management sysytem
1999 VAUXHALL FRONTERRA
KAREN SHINER
Engine Mechanical problem
1999 Vauxhall Fronterra 4 cyl Four Wheel Drive Manual
my 2.2 ltr diesel frontera everytime you dirve a short distance the rev counter stops all of a sudden and then the engine management light comes on the car then goes into what i can only describe as tickover mode chugging a long very slow occasionally stalling but you are able to restart it in a few moments reading a manual it seems to appear that the diesel fule pump is the problem but could it be electrical instead, if we wanted to change the pump ourselves would this be an easy job?
Jan 29, 2009 at 9:34 PM
2CARPRO JACK
  • 11,533 POSTS
If the tachometer (rev counter) is going dead , the computer wont know how to help manage fuel, thus the check engine light (engine management). You need to have the computer scanned for codes, this will lead towards the fix for your car, sounds like it may be a cam or crank angle sensor, but a scan will tell for sure
Jan 30, 2009 at 12:10 AM
