1998 Vauxhall Fronterra Rattling Noise
PIXELMONKEY
Noises problem
1998 Vauxhall Fronterra Four Wheel Drive Manual
Hi, i have a frontera sport 3 door 2ltr 1998.
When i pull away in first gear and when i reverse there is a noticable springy noise like a spring being stretched and released.
I also have a loud rattling noise like metal against metal when i take my foot off the gas which dissappears when the clutch is pressed.
Any help would greatly be appreciated.
Thanks,
Marc.
Feb 3, 2009 at 8:01 AM
DAVE H
  • 13,383 POSTS
sounds like the clutch release bearing needs replacing .. the "spring" noise could also be related to the clutch plate springs .. have the clutch checked !
Feb 3, 2009 at 10:59 AM
PIXELMONKEY
Hi, had a new clutch fitted today and the problem persists. However, the metal to metal rattling noise seems to have eased however that springy noise is still there more so when reversing.
Any more ideas would be greatly appreciated.
Feb 10, 2009 at 8:00 AM
DAVE H
  • 13,383 POSTS
have you checked the clutch pedal spring ? may just need a little lubrication ?
Feb 10, 2009 at 12:20 PM
PIXELMONKEY
Thanks for the replies, would that be inside or outside the car as the noise is coming from underneath and its pretty loud?
Feb 10, 2009 at 12:33 PM
DAVE H
  • 13,383 POSTS
clutch pedal spring, is actually on the clutch pedal itself, underdash.. also some models have a spring on the exhaust system .. you could check the gear linkage is not hitting onto this in some way .. i'm not sure if your model has one fitted .. hava look underneath at exhaust .. try shaking it from side to side ??
Feb 10, 2009 at 12:57 PM
