2001 Vauxhall Corsa Wont change gear properly
2001 VAUXHALL CORSA
BIGGYROCK
Engine Performance problem
2001 Vauxhall Corsa 4 cyl Two Wheel Drive Automatic
Hi, can anyone help! We have a corsa 1.1 automatic, and its just started to play up. It wont change gear properly and the engine maitenance light keeps coming on. It also keeps switchinh from automatic to manual and the gears keep going from 5 to 3 to 1 to 4! Any ideas!!!!!!. Once its past 3rd gear it drives smoothly but the light still comes on and off (the maintenance light) but the problems start all over again when we stop at lights or something. HELP!!!!!
May 3, 2009 at 9:16 PM
DAVE H
  • 13,384 POSTS
You need to have the vehicle plugged into a vauxhall diagnostic computer or equivalent to determine where the fault lies .. it may not be the gearbox at fault it could be a sensor (VSS Vehicle speed sensor etc. ) that is causing the gearshift to be erratic hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_642.png
May 3, 2009 at 11:04 PM
