HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Vauxhall
Corsa
Interior
Instrument Cluster
Gauges
Speedometer
Not Working
1998 Vauxhall Corsa speedo
LEEJOSE
MEMBER
1998 VAUXHALL CORSA
4 CYL
FWD
AUTOMATIC
55,000 MILES
The speedo has stopped working can you tell me if the speedo is a cable to the gear box or electric
Wednesday, July 15th, 2009 AT 1:19 PM
DAVE H
MECHANIC
There is a VSS (vehicle speed sensor) located on the gearbox housing it probably needs replacing !
Friday, July 17th, 2009 AT 5:42 AM
LEEJOSE
MEMBER
Thanks Dave H
Is the speedo electric or dose it work on a steel cable direct to the gear box
Sunday, July 19th, 2009 AT 5:19 PM
DAVE H
MECHANIC
The speed sensor sends an electrical signal .. there is no cable on youe vehicle !
hope this helps
Monday, July 20th, 2009 AT 7:43 AM
Please
login
or
register
to post a reply.
Related Instrument Cluster Gauge Speedometer Not Working Content
1998 Vauxhall Corsa Corsa 1.4 Gls Speedo Not Working
Electrical Problem 1998 Vauxhall Corsa 4 Cyl Two Wheel Drive Manual Hi I Have A Cosra And The Speedo Doenst Work The Eml Comes On...
Asked by
kazzad1977
1 ANSWER
1998
VAUXHALL CORSA
Speedo Not Working
1999 Vauxhall Corsa 1.6 Speedo Not Working Can You Help
Asked by
rutheeroxx
1 ANSWER
1999
VAUXHALL CORSA
1999 Vauxhall Corsa Speedometer
Other Category Problem 1999 Vauxhall Corsa Engine Size Unknown Wheel Drive Type Unknown Manual 55000 Miles My Speedometer And Milage...
Asked by
evagrey
1999
VAUXHALL CORSA
1999 Vauxhall Corsa Faulty Speedo
Interior Problem 1999 Vauxhall Corsa Engine Size Unknown Two Wheel Drive Manual 50024 Miles My Girlfriend Just Got A Cosra 1. Ltr The...
Asked by
breakmanuk
1 ANSWER
1999
VAUXHALL CORSA
2002 Vauxhall Corsa Speedometer
Electrical Problem 2002 Vauxhall Corsa Two Wheel Drive Automatic 31000 Miles My Speedometer Has Stopped Working For A While Now...
Asked by
kathryn510
1 ANSWER
2002
VAUXHALL CORSA
VIEW MORE
Instrument Cluster Replacement
How to Use a Test Light
Hood Open
