1999 Vauxhall Astra
BRADARMPITT
  • 1999 VAUXHALL ASTRA
Engine Mechanical problem
1999 Vauxhall Astra Front Wheel Drive Manual 186675 miles
17td top fuel pump gone I all so have early model vauxhall cavalier 17td, will it fit my astra, looks eg same and is a gm engine. Or I can pick one up of another astra 17td same shape and gm engine, but not same year will that fit, many thanks for the time reading.
Tuesday, May 12th, 2009 AT 4:32 PM
DAVE H
  • 13,384 POSTS
If it looks the same and the fittings are the same then it should work on your vehicle !! you could try checking with vauxhall regarding part numbers for both vehicles .. you may find both vehicles are fitted with the same pump !!
hope this helps
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_692.png
Thursday, May 14th, 2009 AT 6:06 AM
