Engine Cooling problem
1999 Vauxhall Astra 4 cyl Front Wheel Drive Manual
cooling fan continues running also a/c fan I have replaced control box at bumper under n/s headlight this makes no difference any sugg. Please
Tuesday, March 17th, 2009 AT 2:03 PM
DAVE H
MECHANIC
The PCM (computer) controls fan functions .. so check coolant level is correct ..and check the ECT (engine coolant temp) sensor is functioning correctly or replace the sensor !!
