HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Vauxhall
Astra
Climate Control
Air Conditioner
No Air
1998 Vauxhall Astra
TIDDY1077
MEMBER
1998 VAUXHALL ASTRA
6 CYL
FWD
MANUAL
180,000 MILES
My heater is blowing but not out of the vents
Thursday, April 16th, 2009 AT 1:50 AM
DAVE H
MECHANIC
If it is not blowing from the top vents check the supply pipes are mounted correctly also check the supply door controls are working correctly !
Thursday, April 16th, 2009 AT 5:56 AM
Please
login
or
register
to post a reply.
Related Air Conditioner No Air Content
Air Conditioner
My Air Conditioner Stopped Working Last Year, I Had It Recharged At The Time, But It Didn't Fix It. I've Also Had It Leak Checked, But No...
Asked by
Antabb
1 ANSWER
1986
VAUXHALL ASTRA
GUIDE
Vents No Air Flow
The HVAC system is designed to blow air from either the floor, mid or defrost vents. In the following guide we will show you what to check for depending on the symptoms of...
Inefficient Heater
Think There May Be An Airlock As Heater Is Not Very Efficient. Unable To Locate The Bleed Nipple - I Expected It To Be Located Near / On The...
Asked by
rwnlee
9 IMAGES
1995
VAUXHALL ASTRA
Blower Fan
How Do You Gain Access To The Blower Fan In A Vauxhall Astra 2.0ltr Sri 1999
Asked by
10dave57
1 ANSWER
1 IMAGE
1999
VAUXHALL ASTRA
Smell Of Oil
Smell Of Oil Coming Through The Vents When Driving Had It Checked Out And Said The Gaskets On The Engine Have Odd Leaks, But It Does Not...
Asked by
David Caddick
1 ANSWER
2008
VAUXHALL ASTRA
How to Replace the A/C Blower Motor
Blend Door Actuator Replacement
Air Conditioner - Vacuum Down and Recharge
