my car alarm is not deactivating by my fob?
1996 VAUXHALL ASTRA
RUSSESTEV
Other Category problem
1996 Vauxhall Astra Engine Size unknown Wheel Drive Type unknown Manual 150000 miles
my car alarm is not deactivating by my fob. i tried a couple of days ago to deactivate it with the fob the led light on the fob is working it took about 5 mins before it worked to deactivate it then a couple of days later after setting the car alarm overnight my fob would not deactivate it i replaced the battery in the fob still no joy .i rang green flag home start and he could not deactivate my alarm or bypass it as it was a scorpion and not vauxhall standard fit he tried the fob their was a slight dimming of the sensor light in the vehicle but no deactivation is it more likely to be a fob fault and it needs replacing?the car is immobilised
Dec 15, 2007 at 2:42 AM
DAVE H
  • 13,384 POSTS
a speciailist alarm centre would be better ot advise you on this fault !
Feb 23, 2009 at 9:50 PM
  • 55,423 POSTS
If you have another key fob I would try it, if not can I ask if this is a factory alarm, if not I would remove the alarm because aftermarket alarms are no good. If it is a factory alarm I would program a new fob to see if that works, it is easy to do here is a link to amazon where you can get the key fob for $8.00
https://amzn.to/4dNNI6N
Let us know what you find.
Oct 13, 2024 at 7:15 AM
