Vehicle will not turn off
120,456 MILES • 6.0L • V8 • RWD • AUTOMATIC
DAVID ROWAN
I replaced the ignition switch and the and van still will not shut off. It also has trouble shifting. when I turn the key off the van stutters like its starved for fuel, but will not shut off. could it be that the switch I just purchased is bad?
Jul 12, 2016 at 1:49 AM
KHLOW2008
  • 41,812 POSTS
Could be the cause. Try unplugging the switch connector and if engine cuts off, the switch is at fault.
Jul 13, 2016 at 1:10 AM
