Valvetronic 2DCF no movement identified?
97,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
RHOWARD2242
Since this code and my car being a no start i have replaced the front power distribution box, the fuel filter and regulator, the fuel injectors and the valvetronic actuator motor with all seals and gasket with OEM parts and still she won't start. What else can it be? Have replaces the valvetronic sensors today. So, rule that out. ECU? Wiring harness? Neither the scanners nor ISTA will let me preform a relearn, so i'm lost.
Feb 5, 2023 at 7:57 AM
  • 55,673 POSTS
I assume the engine cranks over. Also, can you run the codes to see what comes up? I would do a CAN scan which will go over the entire car and is easy to do, you can get a CAN scanner (Controller Area Network) from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
and
Here is a list of CAN scanners starting at about $25.00 on Amazon:
https://amzn.to/3DBMlc7
Also, will it run on starting fluid, can you hear the fuel pump come on in the fuel tank when the system is turned on? I need more information to help fix the car.
Feb 6, 2023 at 2:47 AM
