Valve job or complete engine rebuild
94,000 MILES • 2.4L • 4 CYL • 4WD • AUTOMATIC
JOSE ALONZO
I had my car's engine checked for a check engine light that was on. I had a mechanic do a diagnostic check and found little or no compression on the number two cylinder. He suggested an engine rebuild. Would a valve job be just as good?
Jul 24, 2017 at 2:43 AM
  • 55,647 POSTS
It depends on where the lean is, in the piston rings then a engine rebuild. If just a intake or exhaust valve you can get away with a valve job.
The mechanic needs to do a leak down test to find out which.
Please let us know what you find.
Cheers, Ken
Jul 24, 2017 at 12:22 PM
JOSE ALONZO
Thank you, very helpful.
Jul 24, 2017 at 2:23 PM
  • 55,647 POSTS
Please let us know what happens, we are interested to see what it is.
Cheers, Ken
Jul 25, 2017 at 4:58 AM
