Valve adjustment
168,000 MILES • V6 • FWD • AUTOMATIC
TOK2
Does my v6 Accord need a valve adjustment? Its running fine tapping noise briefly in very cold start up. It's got 168 thousand miles. I was told it does not need a valve adjustment, but I'm not sure. It runs fine and only makes a tapping noise in cold weather start ups. I was told it's because it's a quart low on oil. I guess that could have been the problem. Thanks very much. Tom. Honda freak. Lol
Mar 1, 2016 at 6:23 AM
CATAFINA
  • 167 POSTS
It could be that being a quart low is what's causing it. Try using oil slightly higher and see what happens. Also, I recommend you change your oil/filter.
Mar 1, 2016 at 6:33 AM
WRENCHTECH
  • 20,760 POSTS
Honda recommends checking the valve clearance at 60,000 miles or when they are noisy.
Mar 1, 2016 at 8:35 AM
