HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Astro
Engine
Vacuum Hose Diagram
Vacuum hose diagram
JIPJOKER
MEMBER
2003 CHEVROLET ASTRO
I am in need of a vacuum line diagram if at all possible I have some lines I can't find where they hook up.
Sunday, July 25th, 2010 AT 9:37 PM
SATURNTECH9
MECHANIC
There you go.
Sunday, July 25th, 2010 AT 10:59 PM
JORN STANGE
MEMBER
1 POST
1995 CHEVROLET ASTRO
4.3L
2WD
AUTOMATIC
140,000 MILES
Vents in cabin cannot be regulated. No cold air comes out except to floor.
Friday, December 25th, 2020 AT 9:42 AM (Merged)
MECHANIC
Good afternoon.
If you have floor vent, then you have vacuum to the control head.
The vacuum rotary valve behind the dash at the control panel directs vacuum to the different mode doors.
I attached diagrams for you to follow.
Images (Click to make bigger)
JORN STANGE
MEMBER
1 POST
Where is the vacuum-line from the vac-reservoir connected to the intake manifold? This line is missing at the reservoir.
Please
login
or
register
to post a reply.
Related Vacuum Hose Diagram Content
2003 Chevy Astro Not Working Properly
The Ac All Of A Sudden Just Started Blowing Out The Defrost Onto The Window And Not Out The Vents In The Front Only. I Have Tried The Dial...
Asked by
ghelm
2003
CHEVROLET ASTRO
2001 Chevy Astro Air Conditioning Vacuum Hose
Air Conditioning Problem 2001 Chevy Astro 6 Cyl Wheel Drive Type Unknown Automatic 93230 Miles I Can't Get Any Cold Air Or Hot Air...
Asked by
rls3714
1 ANSWER
2001
CHEVROLET ASTRO
1992 Chevy Astro Why
Engine Performance Problem 1992 Chevy Astro V8 Two Wheel Drive Automatic I Have A 1992 Chevy Asto That Has A 350 Tbi Motor In It. When...
Asked by
harleyman1075
1992
CHEVROLET ASTRO
2003 Astro Van, Now Needs New Engine?????
I Have An Astro 2003 With A Vortec V 6, 4.3 L, Running Fine, Took It In For An Oil Change And Transmission Fluid Change And The Repair...
Asked by
fastdog
2003
CHEVROLET ASTRO
1993 Chevy Astro Fuel Pump Harness Keeps Shorting Out
I Am On My 7th Harness In 18 Months. This Last One Only Lasted 2 Weeks. The Local Mechanic Has No Clue And Is Refusing To Put Another One...
Asked by
janah7
1993
CHEVROLET ASTRO
VIEW MORE
Intermittent Misfire
Vacuum Leak Symptoms
Idle High
