Car start but will not run when giving gas. Missing while running.
Feb 28, 2018 at 3:40 PM
MIKE H R
CERTIFIED EXPERT
If you suspect a vacuum leak then follow the ways to detect a vacuum leak. If a leak is found the engine will change and run rough until the spray is evaporated.
