Here is a link on a radio removal for a Highlander. In the first step he removes that panel with the power port. Everything is held by plastic clips so the video will show you what to use and where to pry the panel out.
https://youtu.be/EZpSkmwugAk
If it is a little different design, the concept is still the same on removing the panel. Let us know if this helped you.
May 20, 2018 at 9:50 AM
