There is a crack in the plastic connecting to the wheel does it need to be replaced?
106,300 MILES • 1.3L • 2WD • MANUAL
BETHHRXOX
i have very recently passed an mot on my car about 3 weeks ago. I checked under the rear wheel arches to see how it is doing rust wise and i noticed a crack in the plastic connecting to the wheel. I was just wondering what the name of this was so i can seek info.
Aug 28, 2021 at 12:38 AM
STEVE W.
  • 15,405 POSTS
Could you take a picture of the part in question please and post it on here using the add image link? At the moment I'm not sure which area you are looking at that could be cracked.
Aug 28, 2021 at 2:27 AM
BETHHRXOX
Hi Steve, I tried to attach a photo and it wont take the file. it is the dust tube of the shock absorber. :) thanks
Aug 28, 2021 at 5:56 PM
STEVE W.
  • 15,405 POSTS
Okay, those are there to keep dust and crud off the strut area. The rear ones are generally something added after purchase and come as a split item that is added on unless someone added solid ones with replacement shocks. The front ones are a bit more complex as those need to have the struts removed and disassembled to replace them. In both cases they provide some protection of the sliding ram and seals but they are not a critical item. I would likely say you can wait until the shock or strut requires replacement and do it all then.
Aug 29, 2021 at 4:30 AM
BETHHRXOX
Thank you so much!
Aug 29, 2021 at 9:39 PM
STEVE W.
  • 15,405 POSTS
You're welcome.
Aug 30, 2021 at 1:51 AM
