CALVINDAVIES32
My car is going in for it's MOT this week and the Engine Management light is on. The light has been on for a couple of years now but I have heard that it will now result in an MOT fail... is this true? or will it only result in an advisory?
Many thanks,
Calvin
May 7, 2013 at 2:33 AM
it is on for a reason and needs to be checked.
what is the code??
roy
May 7, 2013 at 10:51 AM
CALVINDAVIES32
Thanks for getting back to me Roy,
I took my car to a garage when the light first came on a couple of years ago. The lad said it getting a reading was simple and took less than a minute, but they wanted to charge me £30! I thought that was way too expensive for a minutes work and after he warned the codes don't always tell you the problem with 100% accuracy, and may require further diagnoses I declined. He advised on the most common causes of the light to come on and listed some symptoms to look out for, but said there was no need or legal requirement to have the light off. For a couple of years now I haven't had any of the symptoms or had any change to my fuel economy, so if the light will not result in an MOT fail as it has done previously, I can continue to drve safely and happily. If it will now result in a fail then this may be the year I am finally priced off the road, which has been coming for a while now.
So to re-post my original question; Will a lit Engine Management light result in a fail at my car's MOT test next week?
Many thanks,
Calvin
May 7, 2013 at 8:43 PM
yes it will.
roy
May 8, 2013 at 9:45 AM
CALVINDAVIES32
Thanks very much Roy.
May 8, 2013 at 11:58 PM
