Code U05A0
136,857 MILES • 4 CYL • 2WD • AUTOMATIC
JAYSTER00
I scanned my car listed above today and I received a U05A0 code. It says invalid data received from evaporative emission (EVAP) leak detection system control module. Does anyone know what’s wrong? Should I clear the code or take it in to get looked at?
Jan 11, 2021 at 7:36 AM
JAYSTER00
*mileage is in kilometres not miles.
Jan 11, 2021 at 10:53 AM
4DRTOM
  • 467 POSTS
You should clear the code get the check engine light to go out then go for a drive and if the check engine light comes back in rescan it and get the fresh code before you plan in bringing it to a shop. Its a minor code and your probably not getting any performance issues. A common thing with an evaporate code is a loose gas cap so make sure it's on tight after you clear it and go for a drive.
Let me know what happens and what code gets triggered again.
Tom
Jan 11, 2021 at 4:22 PM
JAYSTER00
Thanks! It worked.
Jan 12, 2021 at 1:55 AM
  • 55,710 POSTS
4DRTOM is one of our best!
Jan 12, 2021 at 11:17 AM
