Multiple U-codes and P-Codes! What can it be?
2006 DODGE CHARGER
140,487 MILES • 5.7L • V8 • RWD • AUTOMATIC
CARLOS88GZZ
U0101, U110C, U0121, P0627, P0481, P0480, U1120, U0103, U110A, U0141, U1403, U1411, U110E, U110F, U1113 and P0571.
I need help I'm getting all those codes on my 2006 Dodge Charger RT also when I turn off the car it won't turn off right away it's does it for a couple seconds then turns off I don't know what it could be
Jul 6, 2015 at 2:10 PM
HMAC300
  • 48,601 POSTS
check battery for condition including load test poor battery will do that. then have a pro look at it due to may be a can bus problem also check fuses.
Jul 6, 2015 at 11:47 PM
BODILLIE
I had a 2006 Commander with same problem . Check the wiring that goes from inside to the drivers door . Peel back the rubber sheathing that protects all those wires . Mine had 8 wires broken . Good Luck
Mar 20, 2018 at 7:12 AM
  • 55,224 POSTS
Great addition to this thread! Please feel free to help out whenever you are on the site :)
Cheers, Ken
Mar 23, 2018 at 2:57 AM
