Turn signal flashers
85,000 MILES • 2WD • AUTOMATIC
DONDREJKA
Sometimes I have a flasher sound, and sometimes there is no sound, but they are working properly.
Jun 12, 2020 at 2:49 AM
So just to be clear when you say you hear a flasher noise, you mean when you turn the signals on you hear the clicking some times and other times you do not hear the clicking but the turn signals always work?
Jun 12, 2020 at 10:19 AM
DONDREJKA
He asked a good question. Yes, the answer to his question is the turn sound is audible and sometimes not audible when signal was in use.
Jun 19, 2020 at 5:22 AM
The turn signal relay is what makes the clicking noise but on your vehicle it uses the BCM and not a relay. So if there is no relay, then there is no clicking noise. Most customers would not be okay with their turn signals not clicking so that is reproduced by the BCM. So if yours is not clicking intermittently then the BCM is at fault for that. If it were me, I would not replace it just for this.
Let me know if you have questions. Thanks
Jun 19, 2020 at 12:08 PM
