Turns over but will not crank and dash lights going crazy
1996 CHEVROLET 1500
200,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
APRIL CRAVEY DEATON
Sometimes it cranks and sometimes it will not. When turning the key sometimes it cranks or at least turns over other times it would not do anything. I just changed the ignition now it is turning over every time. sometimes it will crank but when it does it usually shuts off immediately. All my dash lights are going crazy! I unplugged my light and plugged them back in suddenly it started running fine. managed to drive to the gas station with no issues, but when I left the gas station headed home I had my headlights on and as soon as I hit a bump in the intersection all my dash lights including my stereo started going nuts again and the engine started trying to cut out. Also, when the key is turned to the on position the throttle body is making a weird noise. I have already sunk $25,000.00 in this truck mechanically I am on the third motor and second transfer case in this truck since I bought it. I cannot keep sticking money into it. I have been to several different shops and each one gave me a different answer to the problem.
Oct 17, 2017 at 2:01 AM
  • 55,423 POSTS
It definitely sounds like a connection or short problem. I would start with a new battery because it can have an intermittent internal short then I would check the ground cable/strap from the engine to the frame of the truck. The frame must be grounded to the engine for the electrical system to work right.
Also, check all battery cable connections to make sure they are clean and tight.
Here are two guides that should help:
https://www.2carpros.com/articles/how-to-replace-a-car-battery
and
Please let us know what you find. I'm interested to see what it is.
Cheers, Ken
Oct 18, 2017 at 4:58 AM
APRIL CRAVEY DEATON
Took my trailer lights harness off everything is working fine now
Oct 18, 2017 at 11:35 AM
  • 55,423 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Cheers, Ken
Oct 19, 2017 at 4:17 AM
