Does not start after replacing the throttle body unit and serpentine belt?
247,543 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
MARK MAYO2
I replaced my throttle body Unit and serpentine belt at same time and now my vehicle won’t start.
Mar 1, 2023 at 6:53 PM
  • 55,732 POSTS
Hello Mark,
Please remove the throttle bore inlet tube and use a flashlight to observe the butterfly while a helper tries to start the engine, you should see the butterfly move open slightly allowing the engine to start. Also, have the helper push the throttle down slightly while cranking to see if the engine starts, in which case the computer will try to relearn the butterfly position. If this doesn't work let's run the codes to see what comes up.
Let us know what happens and please upload pictures or videos of the problem.
Mar 2, 2023 at 11:06 AM
MARK MAYO2
That was helpful information though the problem ended up being that I caused my ECM to dump my security key code(s), my keys have chips in them, so my ECM placed my truck in an inoperable state. Had to pay a guy to come to my truck and reset the key codes in the ECM. A cautionary event. Never listen to someone when they say you can remove your ECM fuse/relay rather than disconnecting the negative cable! If your keys have a chip inside them removing the fuse or relay to your ECM is a huge mistake!
Mar 3, 2023 at 7:46 AM
  • 55,732 POSTS
Great information. Thanks for letting us know, we are here to help, please use 2CarPros anytime.
Mar 4, 2023 at 3:11 AM
