Truck will not restart after it has been running for thirty minutes or so
1989 GMC C2500
175,000 MILES • 5.7L • V8 • 2WD • MANUAL
GSCOTTBROWN
Truck starts fine when engine is cold. After I drive it for a while turn it off and try to restart the engine it will not restart. The starter does not seem to want to turn over the engine. Once it sets for a while it will then start.
I have replaced the following:
Starter
Battery
Distributor
Park Plugs and wires
Battery cables and ground down the connections to ensure I got good contact.
Planning on replacing ignition coil next. Any suggestions on what is causing this or what to change next?
Thanks
Apr 26, 2019 at 8:32 AM
  • CERTIFIED EXPERT
  • 53,888 POSTS
What brand of starter did you use? I recommend AC Delco only. Can you please shoot a quick video with your phone so we can hear the noise? that would be great. You can upload it here with your response.
This guide can help as well:
Apr 27, 2019 at 11:45 AM
