Engine will not stay running?
2007 CHEVROLET 1500
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
BHALLET701
I have the truck listed above that was stolen from me a while back. When I crank it over it starts up for a few seconds but shuts off shortly after. I already changed out the fuel pump, didn't fix the problem. I have a feeling it is something electrical because it wants to run. But it just acts like it isn't getting fuel. My father said something about replacing the 02 idle control sensor. Located on the carb on top of intake. I am open to suggestions I really need some type of transportation.
Nov 30, 2022 at 2:34 AM
  • 110,244 POSTS
If the idle air control valve were an issue, you would be able to keep it running by pressing the throttle. Is that the case?
Have you tried to retrieve diagnostic trouble codes? Here is a link that explains how it's done:
Next, is the security light staying on or flashing, or does it turn off indicating the correct key is being used?
Nov 30, 2022 at 1:25 PM
