Truck runs bad
250,000 MILES • 2.7L • 4 CYL • 4WD • MANUAL
JAMES CLINTON
Have a misfire on cylinder one and two, 30 lb of compression on one no compression on 247 on 3 and 150 on 4 when you start it up it runs real bad the warmer it gets. the battery runs, but it still misfires. new plugs, new wires, new coil packs, all injectors work.
Dec 30, 2017 at 3:28 AM
  • 31,937 POSTS
sounds as if you have a blown head gasket, and it may be leaking between number one and number two cylinders, a leak down test will prove this. also, a wet compression test will show if it is a valve and gasket problem. just add a small amount of engine oil into the cylinder to be tested, just a few squirts from an oil can enough to coat the rings, this will seal the rings for the test. if the compressions do no increase the leak is at the top of the engine, being gasket or valves.
Dec 30, 2017 at 6:42 AM
JAMES CLINTON
How hard would it be to put a 2.4 L out of a 2002 Toyota into my 1998 Toyota Tacoma any difference in the wiring harnesses?
Dec 30, 2017 at 11:03 AM
  • 31,937 POSTS
Not sure, but i feel that there will be some differences, including the PCM.
Dec 30, 2017 at 2:38 PM
