Trouble cranking
2005 CHEVROLET 1500
136,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
BAMACRAFT
Battery and starter relay have been replaced but the truck sporadically cranks. Sometimes the engine will turn over and crank every time I turn the key. Other times, it will crank once and if I turn it off, it won’t crank again for the rest of the day. There doesn’t seem to be a noticeable pattern. When the truck is running, there are absolutely no issues at all. I have a new starter but haven’t replaced it yet. I was hoping for some advice before I took the next step. After reading that it may be a glitch with the anti theft system, I followed the advice on unhooking the battery and then letting it sit overnight before reconnecting. That worked sometimes but not 100%. What might be causing this or what should I be looking at to try and locate the source of the problem?
Dec 27, 2018 at 11:01 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Lets try this first. Here is a link to resetting your Anti-Theft system. Scroll to the bottom the see the Chevrolet application.
https://www.2carpros.com/articles/how-to-reset-a-security-system
After this let me know what happens and we'll go from there. Hope this helps and thanks for using 2CarPros.
Danny-
Dec 27, 2018 at 2:57 PM
