Car does not move in either drive or reverse
135,000 MILES • 0.6L • 4 CYL • 2WD • AUTOMATIC
ROBERT CORNERSTONE
my problem is, the car does not move if the gear lever is shifted to either drive or reverse.
Sep 6, 2016 at 4:23 PM
HMAC300
  • 48,601 POSTS
make sure transmission is shifting first then have a transmission professional look at it, he has to check fluid anyhow as there may not be a dipstick. if it moves in any gear it may be in limp mode which a scanner will need to be attached or it is an internal problem.
Sep 6, 2016 at 11:54 PM
