transmission will not shift into third or fourth gear
227,000 MILES • 3.0L • 6 CYL • 4WD • AUTOMATIC
D-DUKES
i recently changed my alternator and doing this the right front axle has to come out . everything went pretty smooth putting everything back together and when i test drove it the transmission fluid came out because i did not replace the axle seal. I replaced the seal and had no leaks but since. i lost some fluid the transmission was slipping just a little bit. so i topped it off with Mercon V and now i only have first and second gear and reverse is fine. What i am not sure of is, does my vehicle take Mercon or Mercon V ? Most stuff i read says the V but my dipstick says Mercon . can you mix the two ? and also the vehicle runs great and sounds good, it just will not shift.
Sep 7, 2017 at 10:32 AM
  • 55,694 POSTS
As you drive does the speedometer work?
Please let us know
Cheers, Ken
Sep 8, 2017 at 4:06 AM
D-DUKES
speedometer works fine . everything seems to be working great . it just wont shift.
Sep 10, 2017 at 6:52 AM
  • 55,694 POSTS
It sounds like a shaft speed sensor has gone out, lets start by running the codes to see what come up.
Here is a guide to get you started.
Cheers, Ken
Sep 11, 2017 at 3:57 AM
D-DUKES
check engine light has not come on but i scanned it anyway and it didnt show anything .
Sep 11, 2017 at 7:55 AM
  • 55,694 POSTS
Bummer, I would start to lean toward the transmission has gone out and needs a rebuild. You can pull it yourself and save some money. I would replace the radiator also so the cooler doesn't inject old fluid and material into the new unit.
Here are a few guides to show you what you are in for when doing the repair.
https://www.2carpros.com/articles/how-to-replace-a-car-radiator
and
https://www.2carpros.com/articles/transmission-replacement-removal-manual
Cheers, Ken
Sep 12, 2017 at 3:28 AM
