Transmission whining and slipping, check engine light on and code P0700
208,329 MILES • 3.8L • V6 • 2WD • AUTOMATIC
RANDY HAWKS
  • 5 POSTS
Here within the past 2 weeks my transmission started whining and hesitates or slips while driving. It does it in reverse and forward gears the check engine light came on and gave the code P0700 it feels like it's stuck between gears. What could cause this and what's the best way to fix it myself?
Nov 29, 2019 at 5:44 PM
Good morning,
The only thing you could do at this point without removing it.
As far as the issue, it could be the front pump whining from lack of fluid. That would be caused by a clogged filter in the transmission. I would drop the pan and change the fluid and filter.
The 700 is just a general transmission code. It indicates there are other codes stored.
Nov 29, 2019 at 8:38 PM
RANDY HAWKS
  • 5 POSTS
When I check the fluid leaves it is full and it did not read any other codes.
Nov 30, 2019 at 3:52 AM
Okay, did you change the fluid and filter?
Nov 30, 2019 at 4:05 AM
RANDY HAWKS
  • 5 POSTS
Not yet, I'm getting ready to go get the stuff now.
Nov 30, 2019 at 4:10 AM
Okay, keep me updated.
Nov 30, 2019 at 4:24 AM
RANDY HAWKS
  • 5 POSTS
Will do, thanks.
Nov 30, 2019 at 4:26 AM
You are welcome.
Nov 30, 2019 at 4:28 AM
RANDY HAWKS
  • 5 POSTS
I changed the filter and fluid and the whining stopped and shifts just like it should now. thank you for your help. I was so afraid that I was going to need a new transmission.
Dec 2, 2019 at 10:52 PM
Good deal. Glad it is fixed.
Dec 2, 2019 at 11:04 PM
